Gauthier_Auvray
3 years agoplatform designer generation
Hi, I would like to use the "generate tcl file for project" feature to be able to re-create and build a project on a CI system (the design uses Platform Designer). 1. I can generate the TCL file of...
FvM
3 years agoHello,
by using VHDL instantiation syntax "entity <library>.<component>", you need IP components generated in VHDL.
Global parameter HDL_PREFERENCE has been introduced in Quartus 17 as far as I'm aware of. Most simple solution is probably to regenerate the IP HDL manually, chosing the respective language.
Frank
