Platform Designer error, Cyclone-V SOC, generate_hps_sdram.tcl
Hi all,
I'm trying to generate the HDL files for a Cyclone-V SoC. Unfortunately, the generation fails with the attached messages:
Error: border: Error during execution of script generate_hps_sdram.tcl: seq: Error during execution of "{C:/intelfpga_lite/19.1/quartus/../nios2eds/Nios II Command Shell.bat} make all 2>> stderr.txt": child process exited abnormally Error: border: Error during execution of script generate_hps_sdram.tcl: seq: Execution of command "{C:/intelfpga_lite/19.1/quartus/../nios2eds/Nios II Command Shell.bat} make all 2>> stderr.txt" failed Error: border: Error during execution of script generate_hps_sdram.tcl: seq: child process exited abnormally Error: border: Error during execution of script generate_hps_sdram.tcl: seq: add_fileset_file: No such file C:/Users/ALBERT~1.FAR/AppData/Local/Temp/alt9052_495511809790755470.dir/0004_seq_gen/hps_AC_ROM.hex Error: border: Error during execution of script generate_hps_sdram.tcl: Generation stopped, 3 or more modules remaining Error: border: Execution of script generate_hps_sdram.tcl failed Error: border: 2022.03.01.09:06:53 Info: Error: border: ******************************************************************************************************************** Error: border: Error: border: Use qsys-generate for a simpler command-line interface for generating IP. Error: border: Error: border: Run ip-generate with switch --remove-qsys-generate-warning to prevent this notice from appearing in subsequent runs. Error: border: Error: border: ******************************************************************************************************************** Error: border: 2022.03.01.09:06:57 Warning: Ignored parameter assignment device=5CSEBA2U19C8S Error: border: 2022.03.01.09:06:57 Warning: Ignored parameter assignment extended_family_support=true Error: border: 2022.03.01.09:07:02 Warning: hps_sdram: 'Quick' simulation modes are NOT timing accurate. Some simulation memory models may issue warnings or errors
There are more messages than this.
This same project compiles OK on a Linux platform, the failures are on a Win10 platform. I've tried Quartus 21 and 19 with a patch applied, and the same error persists. Unfortunately the Linux machine is just an old test device, and it takes quite a while to compile.
Any ideas, has anyone else experienced this? Happy to try other things if necessary.
Cheers,
Alberto
- EricMunYew_C_Intel
You can refer to below.
https://www.intel.com/content/www/us/en/support/programmable/articles/000086438.html
- Alberto_F
Hi, thanks for your reply. WSL2 is installed on the machine, but the link within the link provided does not work unfortunately!
Alberto
- Alberto_F
thanks, yes, the link and the solution did work well!
Cheers,
Alberto
- dschumerth
I had the same issue and after trying the steps that worked for others, I still had the same issue. What I ended up doing was running Quartus as administrator.
My work laptop had a group policy that prevents .bat files from being ran with standard privileges. The platform designer makes a call to "Nios II Command Shell.bat" but the error shown looks like WSL is not installed or that "make" was not installed inside WSL.
~David Schumerth
