CAlex
Contributor
2 years agoPlatform designer error : subsystem ava mm bridge slave port
Hi, Ive made a subsystem into my main system: here is my sub system: The error is : Error: soc_system.subsystem_0.mm_bridge_0_s0: Interface must have an associated clock Reguards Al...
- 2 years ago
At Component Editor Signals & Interfaces tab, add Clock Output and Reset Output signals check screenshot below:
Then modify the Clock Output and Reset Output Signals setting like below screenshot:
Sheng
ShengN_altera
2 years agoHi,
The reset sink is the Reset Input. You may in Associated reset sinks put reset and then click finish. Then the warning will gone.
Sheng
- CAlex2 years ago
Contributor
It is solved ,thank you
