CAlex
Contributor
2 years agoPlatform designer error : subsystem ava mm bridge slave port
Hi, Ive made a subsystem into my main system: here is my sub system: The error is : Error: soc_system.subsystem_0.mm_bridge_0_s0: Interface must have an associated clock Reguards Al...
- 2 years ago
At Component Editor Signals & Interfaces tab, add Clock Output and Reset Output signals check screenshot below:
Then modify the Clock Output and Reset Output Signals setting like below screenshot:
Sheng
ShengN_altera
2 years agoHi,
Sheng
CAlex
Contributor
2 years agoHI
It is working!
very thank you for the help
But there is a warning said associated reset sink not detected.
Here is my IP setting for reset_out:
Here is my sub_system:
If that is not critical, then I'll ignore that.
Reguards
Alex
