CAlex
Contributor
2 years agoPlatform designer error : subsystem ava mm bridge slave port
Hi, Ive made a subsystem into my main system: here is my sub system: The error is : Error: soc_system.subsystem_0.mm_bridge_0_s0: Interface must have an associated clock Reguards Al...
- 2 years ago
At Component Editor Signals & Interfaces tab, add Clock Output and Reset Output signals check screenshot below:
Then modify the Clock Output and Reset Output Signals setting like below screenshot:
Sheng
ShengN_altera
2 years agoHi,
The Custom Reset Synchronizer is your custom IP? If replace Custom Reset Synchronizer with Clock Source Intel IP any difference?
If no more error means the problem at the Custom Reset Synchronizer.
Sheng
- CAlex2 years ago
Contributor
Hi
yes you are right, the sync reset block is the problem of the issue,
but it was not my IP, it is combined with the GHRD of CycloneVsoc.
What this IP do to the clk is
assign clk_out = clk_in;
I dont understand why it will return such a error for my system.
Reguard
Alex
