CAlex
Contributor
2 years agoPlatform designer error : subsystem ava mm bridge slave port
Hi, Ive made a subsystem into my main system: here is my sub system: The error is : Error: soc_system.subsystem_0.mm_bridge_0_s0: Interface must have an associated clock Reguards Al...
- 2 years ago
At Component Editor Signals & Interfaces tab, add Clock Output and Reset Output signals check screenshot below:
Then modify the Clock Output and Reset Output Signals setting like below screenshot:
Sheng
ShengN_altera
2 years agoHi,
Check the Clock tab, is that the Avalon-MM Pipeline Bridge Clock Input being connected correctly?
I'll encounter the same problem when Clock Input is not connected check screenshot below:
If the problem still persist even the Clock Input is connected properly, then probably try to replace with a new Avalon-MM Pipeline Bridge IP and see.
Sheng
- CAlex2 years ago
Contributor
HI
The problem still exist, the clk is connected properly:
Reguards
