CAlex
Contributor
2 years agoPlatform designer error : subsystem ava mm bridge slave port
Hi, Ive made a subsystem into my main system: here is my sub system: The error is : Error: soc_system.subsystem_0.mm_bridge_0_s0: Interface must have an associated clock Reguards Al...
- 2 years ago
At Component Editor Signals & Interfaces tab, add Clock Output and Reset Output signals check screenshot below:
Then modify the Clock Output and Reset Output Signals setting like below screenshot:
Sheng
sstrell
2 years agoThe exported interface names for clock and reset in the second image do not seem to match the clock and reset interface names of the subsystem in the first image. I'm not sure why the names are different, but it might just require a refresh or edit and save of the subsystem to correct.
- CAlex2 years ago
Contributor
Hi
you are right for the name error and is solved,
the main error still exist though,
Thank you for the help by the way
