Platform designer 21.3 pro missing clock_source block
Hi there,
I am using Intel Quartus Prime Pro 21.3 and I'm attempting to create a NIOS II subsystem through platform designer 21.3. The problem I have is that there is no clock_source block so I can't create a clock for my system. All I have access to is a clock_bridge (totally not what I want). Does anyone know where the clock_source block has gone? Or what I need to do in order to import the ip core on its own?
Alex
It doesn't exist in Pro. It was broken up into the clock and reset bridge IPs, which behave exactly the same. If you have a Standard design that does include the clock source component, it will still work in Pro, but you can't create a new clock source component in Pro.
- sstrell
- AlexBeasley
Hi there,
Thanks for your quick response. So, potentially silly question incoming, but if I have a NIOS II design and I'm using a clock and reset bridge, what frequency clock should be passed to the NIOS II core? (I did try with a 50MHz clock being passed through the FPGA fabric via a clock bridge into a NIOS II design, however this failed when attempting to program the NIOS)
Alex- sstrell
Whatever clock speeds that are supported by Nios should work. I don't know them off-hand. Whether it's the clock source component or the clock bridge, it's basically just wires distributing the clock to components in the system, so it should not affect the operation of components in the system if you change the IP to the clock bridge.
- EBERLAZARE_I_Intel
Do you still encounter the issue?
- KennyT_altera
Not sure if this issue is solved? Kindly expect some late reply as the owner is taking some leave until next week.
- AlexBeasley
Yes this is resolved, I accepted one of the previous answers
