AlexBeasley
4 years agoPlatform designer 21.3 pro missing clock_source block
Hi there,
I am using Intel Quartus Prime Pro 21.3 and I'm attempting to create a NIOS II subsystem through platform designer 21.3. The problem I have is that there is no clock_source block so I c...
- 4 years ago
It doesn't exist in Pro. It was broken up into the clock and reset bridge IPs, which behave exactly the same. If you have a Standard design that does include the clock source component, it will still work in Pro, but you can't create a new clock source component in Pro.
KennyT_altera
4 years agoNot sure if this issue is solved? Kindly expect some late reply as the owner is taking some leave until next week.
AlexBeasley
4 years agoYes this is resolved, I accepted one of the previous answers
