Platform designer 21.3 pro missing clock_source block
- 4 years ago
It doesn't exist in Pro. It was broken up into the clock and reset bridge IPs, which behave exactly the same. If you have a Standard design that does include the clock source component, it will still work in Pro, but you can't create a new clock source component in Pro.
Hi there,
Thanks for your quick response. So, potentially silly question incoming, but if I have a NIOS II design and I'm using a clock and reset bridge, what frequency clock should be passed to the NIOS II core? (I did try with a 50MHz clock being passed through the FPGA fabric via a clock bridge into a NIOS II design, however this failed when attempting to program the NIOS)
Alex
Whatever clock speeds that are supported by Nios should work. I don't know them off-hand. Whether it's the clock source component or the clock bridge, it's basically just wires distributing the clock to components in the system, so it should not affect the operation of components in the system if you change the IP to the clock bridge.
