Arintel
6 years agoPlatform Designer - PCIe-DMA BAR size
Hello Everyone, I used Quartus 20.1 to generate the Example Design of "Arria 10 PCIe-Avalon-MM-DMA". I then used Platform Designer to add an "Avalon-MM Clock Crossing Bridge" IP core. I connected rm...
Arintel
6 years agoRahulS,
I now think that the problem was actually because I did not click on "Sync System Infos" or turn on the Auto sync button.
Anyway, the Auto-assign feature should be used for all base addresses. It compacts the address space for you.
Ari
