ALMSlinger
2 years agoPlatform Designer - clock bridge : Interfaces must be on the same clock domain
Hi, To split up the a large clock tree, I inserted a clock bridge in my platform designer file. Now, I have one PLL generated clock CLK --> clk bridge --> cout_0, cout_1, cout_2. The clock bridge...
ALMSlinger
2 years agoThey use common reset that is synchronous to the clock generated by the pll. The same clock that is input to the clock bridge. I even tried to add a parallel reset bridge which did the same thing as the clocks. But that doesn't help. I get the same error.
Thank you.
Best regards.
sstrell
2 years agoCan you show screenshots of parameters and how you're connecting things?
