Pipeline parameter issues for LPM_Divide
Hey sstrell,
Thank you for your reply.
I made a screenshot of my timing analyser:
- First the statistics showing the delay coming from the cells.
- Data Arrival Path showing my clock delay 0.619 ns, then the delay for the data path 4.328 ns.
- .sdc file showing the constrained inputs and outputs, plus the generated PLL 250 MHz and set_multicycle_path for controlling the setup and hold for my outputs.
Unfortunately I can't really understand the cause of this timing error, I know it's coming from a lot of cells and ICs, but only from LPM_DIVIDE_component.
I also tried to add a component between the adder and divider to slow down the incoming data for one clock but it didn't work.
If you have any thoughts on how we can manage to control the timing error, I'd appreciate it.
thanks in advance
