Pin Migration Cyclone 10 GX
I am using Pin Planner to verify the pin compatibility between C10GX150 and C10GX220.
I saw high lightened pins in bank 2L for unknown reason, please forward to attachment.
Should I skip this and suppose those 2 devices can work as well?
If not, then what should I do?
Thank you!
Johnson
Pin function or I/O back column will be NC.
- We have to Compare the PINOUT file and find the difference and check it with respect to pin connection guidelines
- If we are doing Quartus design migration we can change the device PN and compile the design and check.
Anand
- AnandRaj_S_Intel
Hi Johnson,
Which version of tool are you using?
I have check it using Quartus 19.1 pro. Nothing is been lightened Attached the report.
Also try pin-out files comparison.
Anand
- JLee25
Contributor
Hi Anad,
Thank you for getting back.
I am using Quartus Prime Pro Edition Ver. 18.0.1 Build 261 for the fit.
If the migration has problem, what message it will show to indicate the error?
Johnson
- AnandRaj_S_Intel
Anand
