JLee25
Contributor
7 years agoPin Migration Cyclone 10 GX
Hello, I am using Pin Planner to verify the pin compatibility between C10GX150 and C10GX220. I saw high lightened pins in bank 2L for unknown reason, please forward to attachment. Should I s...
- 7 years ago
Pin function or I/O back column will be NC.
- We have to Compare the PINOUT file and find the difference and check it with respect to pin connection guidelines
- If we are doing Quartus design migration we can change the device PN and compile the design and check.
Anand
AnandRaj_S_Intel
7 years agoHi Johnson,
Which version of tool are you using?
I have check it using Quartus 19.1 pro. Nothing is been lightened Attached the report.
Also try pin-out files comparison.
Anand
