10 years agopin assignment - unused GPIO pins
Hi there,
I´m using the GPIO pin header of the DE2 - 115. I´m finished with the pin assignment, but there are several pins unused. But i don`t want to have them floated, so i want to define them. I already read, that it is possible to connect them via 0 ohm resistor to gnd or Vcc. But in that case, they used a standard routing file from altera. I cannot use this file, but i want to define the gpio pins completely, to avoid damaging the board and the connected module. Is it possible to: - find the unused pins automatically - define their states, but without using them in the project or is it necessary to include I/O pins in the project to assign the unused pins to a state? Perhaps there is an other way to assign unused pins? Thank you in advance. kind regards
