AGaru1
6 years agoPCIe HARD IP +
Hi, i'm trying to run a synthesis of my Design for Stratix 10 on Quartus Pro 19.4. In my TOP ENTITY i added the PCIe HARD IP + and connected it to my entities. I've updated the .qsf file with the...
BoonT_Intel
6 years agoHi Sir,
Yes, maybe you can generate the IP, then set the IP top level file as the design top level, run analysis and synthesis (a&s) see if you still get the same error. If the IP not demonstrate the error, the you can generate the IP example design (ED) and perform a&s. If it pass, then you can compare it to your design top level, if the ED fail, then send the design QAR to me.
