10 years agoPb with shifting
architecture behave of convo is
signal rg: std_logic_vector(1 downto 0):="00";
signal c1: std_logic_vector(31 downto 0);
signal c2: std_logic_vector(31 downto 0);
begin
process(clk)
begin
if (clk 'event and clk='1') then
for i in 0 to 31 loop
c1(i)<=wr_data(i) xor rg(1);
rg(1)<=rg(0); :confused:
rg(0)<=wr_data(i); :confused:
end loop;
end if;
end process;
C1_out<=c1;
--C2_out<=c2;
end; Hello mates, I am having problem with my code : the instructions" rg(1)<=rg(0); and rg(0)<=wr_data(i); " seems that they r not working I start my waveform(with no error in synth) and the result show that it is keep doing c1(i)<=wr_data(i) xor rg(1); for the initial rg(1) !!! What could be the problem ? is it code syntax or what ?!2 Replies
rg(0) is always assigned to wr_data(31), because signals take the last value assigned to them. did you mean for rg to be a variable?
--- Quote Start --- rg(0) is always assigned to wr_data(31), because signals take the last value assigned to them. did you mean for rg to be a variable? --- Quote End --- Yes I need rg(0) to be assigned to wr_data(i) ( same for assigning rg(1)) as you said rg should be variable every iteration
