Partition that will be filled in by QDB file - shouldn't need an 'entity'
I require some assistance with Quartus Pro Edition (17.1) incremental compilation.
I have a project called 'simple'. It has a single top VHDL file called simple.vhd:library ieee;
use ieee.std_logic_1164.all ;
entity simple is
port (
input: in bit;
clk : in std_logic ;
output :out bit
end simple;
architecture rtl of simple is
component sub
port (
input: in bit;
output :out bit
end component;
begin
SC: component sub
port map(
input => input,
clk => clk,
output => output
end rtl;
The 'sub' module is a very simple module that was compiled in a separate project. It has a single top VHDL file called sub.vhd: library ieee;
entity sub is
port (
input: in bit;
output :out bit
end sub;
architecture rtl of sub is
begin
output <= input;
end rtl;
In the 'simple' project, I wish to include only the component declaration, component instantiation, and QDB file for 'sub'. The component declaration and instantiations are shown in the VHDL above. I do not want to include the entity declaration here because the entity's inclusion is generally not required when reusing a synthesized netlist (verified in Quartus Standard as well as other HDL compilation tools). What I mean here, is that generally all that is required for reusing a synthesized netlist, is the netlist itself and a component declaration (i.e. the stub). So, I should not have to include an entity declaration in the project when all I wish to do is use a QDB file that contains the already-synthesized 'sub' module. I have gone through all of Intel/Altera's Incremental Block-Based Compilation training, and I have not been able to determine how to have 'sub' be truly just a netlist and a component-declaration stub file. I am having the following issues. 1. I cannot reuse the synthesized 'sub' module if it is the top-module of its project. - There must be something wrong here. It does not make sense that I would have to create a wrapper module for 'sub' in its project just so I can reuse the synthesized results of 'sub' elsewhere....
- I tried exporting the entire 'sub' project via Project -> Export Design, but this did not work because when I imported it in the 'simple' project, it wanted the QDB to represent the 'simple' project itself, not a submodule or partition of the 'simple' project. Similar problem when I used command line quartus_cdb to export the root_partition.
- How can I tell the 'simple' project that it has a sub-module that should be a pre-synthesized partition? I try to run Analysis & Elaboration, but it fails with "Error(16045): Instance "SC" instantiates undefined entity "sub"." So, there is no module hierarchy for me to set design partitions.
- I manually modified the QSF to set the 'sub' module as a partition with a QDB: set_instance_assignment -name PARTITION sub -to SC -entity simple set_instance_assignment -name PRESERVE synthesized -to SC -entity simple set_instance_assignment -name QDB_FILE_PARTITION /data/workspace/sub.qdb -to SC -entity simple
- Finally, I tried adding the entity declaration for 'sub' (which I absolutely should not have to do in 'simple' as it is not required in any other HDL compilation tools). I used the same 3 partition assignments in the above bullet, and I see the following error:
- It seems like I can get different errors if I do things in different orders.... I was able to get a seg fault by then commenting out the 'sub' entity declaration
Note that I have also taken the Design Block Reuse training. The examples of 'black box' VHDL files in this training include the 'entity' declaration as well as 'architecture logic'. I am still confused as to why the black box must be defined in this way as opposed to the more common component declaration. I hope there is a way around this.
Even when I use the 'black box' VHDL from that training:
I still see the following error: Error(19326): The partition "sub" is loaded from a Partition Database File (.qdb) and is set to preserve with a Preservation Level assignment. These two preservation types cannot be combined. I first ran Analysis & Elaboration on 'simple'. Since I added in the entity and logic architectures, this succeeded and provided me with the hierarchy view that included the 'sub' instance. Finally, I set the 'sub' instance as a partition with Preservation Level=synthesized, pointed the QDB file to the one that was exported from the 'sub' partition in the 'sub' project (after adding a dummy top module to the 'sub' project - again I hope this is not the solution...). When I run Analysis & Synthesis, it gives the error mentioned above. Again, any help is much appreciated. -dbanks12library ieee; use ieee.std_logic_1164.all ; entity sub is port ( input: in bit; clk : in std_logic ; output :out bit ); end sub; architecture logic of sub is begin end logic; - Altera_Forum
--- Quote Start --- Note that I have also taken the Design Block Reuse training. The examples of 'black box' VHDL files in this training include the 'entity' declaration as well as 'architecture logic'. I am still confused as to why the black box must be defined in this way as opposed to the more common component declaration. I hope there is a way around this. Even when I use the 'black box' VHDL from that training:
I still see the following error: Error(19326): The partition "sub" is loaded from a Partition Database File (.qdb) and is set to preserve with a Preservation Level assignment. These two preservation types cannot be combined. I first ran Analysis & Elaboration on 'simple'. Since I added in the entity and logic architectures, this succeeded and provided me with the hierarchy view that included the 'sub' instance. Finally, I set the 'sub' instance as a partition with Preservation Level=synthesized, pointed the QDB file to the one that was exported from the 'sub' partition in the 'sub' project (after adding a dummy top module to the 'sub' project - again I hope this is not the solution...). When I run Analysis & Synthesis, it gives the error mentioned above. Again, any help is much appreciated. -dbanks12 --- Quote End --- I determined that you only want to set the Preservation Level to 'synthesized' in the Developer project, and not the Consumer project. By leaving Preservation Level 'Not Set' in the Consumer project, I am able to synthesize successfully using the QDB partition files from the Developer project. Parts of my original question still remain:library ieee; use ieee.std_logic_1164.all ; entity sub is port ( input: in bit; clk : in std_logic ; output :out bit ); end sub; architecture logic of sub is begin end logic;- Do I absolutely need to use a dummy top module to export my module for use as a submodule in another project?
- Do I absolutely need to have the entity declaration in the Black Box file, or is there some way that I can use a component declaration instead as I have done with Quartus Standard?
I have determined that the dummy top module is not needed if using a command-line flow (see https://www.alteraforum.com/forum/showthread.php?t=57908&page=2&p=237221#post237221), but I am still seeing the requirement for the unwanted entity declaration.
- DBay
Did you ever find a way to make this work? I'm trying the same thing in 18.1 and it just plain doesn't work. I feel like I'm back in Quartus 10 where it all sounded good, but nothing worked the way that Altera claimed. It was just broken. It is just broken!
