Couldn't get this to work, heres my code in full. Sorry if I confused the question. What happens is that whenever on_input = '1' then the count increases every time the clk goes +ve. I require it to count up only once no mater how long the on_input is held at '1'. I can see why the design I have operates as it does, but I can't work out how to change it to what I need. I need the overflow to act in a similar way. Thanks.
entity counter is
port (clk : in std_logic;
on_input : in std_logic;
reset : in std_logic;
overflow : out std_logic;
values : out integer range 0 to 255);
end counter;
architecture Behavioral of counter is
signal count : integer range 0 to 255;
begin
counter_process : process (clk, reset, on_input)
begin
if reset = '1' then count <= 0;
elsif rising_edge (clk) and on_input = '1' then
if count < 255 then
count <= count + 1;
end if;
else count <= count;
end if;
end process counter_process;
overflow_process : process (count)
begin
if count > 255 then overflow <= '1';
else overflow <= '0';
end if;
end process overflow_process;
values <= count;
end Behavioral;
