12 years agoCouldn't get this to work, heres my code in full. Sorry if I confused the question. What happens is that whenever on_input = '1' then the count increases every time the clk goes +ve. I require it to count up only once no mater how long the on_input is held at '1'. I can see why the design I have operates as it does, but I can't work out how to change it to what I need. I need the overflow to act in a similar way. Thanks.
entity counter is port (clk : in std_logic; on_input : in std_logic; reset : in std_logic; overflow : out std_logic; values : out integer range 0 to 255); end counter; architecture Behavioral of counter is signal count : integer range 0 to 255; begin counter_process : process (clk, reset, on_input) begin if reset = '1' then count <= 0; elsif rising_edge (clk) and on_input = '1' then if count < 255 then count <= count + 1; end if; else count <= count; end if; end process counter_process; overflow_process : process (count) begin if count > 255 then overflow <= '1'; else overflow <= '0'; end if; end process overflow_process; values <= count; end Behavioral;
