13 years agoOR condition acts like an AND in Verilog?
Short Version:
I have an input to a module and a wire within the module. When either of these are TRUE, I want something to happen. However, only when the input is fixed TRUE and the wire flips to TRUE do I get the behavior I want. So the OR is acting like an AND. The code snippet is
input hard_reset;
wire timer_reset;
assign max_reset = (timer_reset | hard_reset); but I only get things to work like I want them to when hard_reset is fixed high, then things are controlled just by timer_reset. Thus, it is an AND. Any idea what is happening? Long Version: I am writing code to do pulse counting with the MegaWizard LPM-Counter function. I have two counters, one counting incoming pulses to my DE2 board and another counting clock 50MHz clock cycles up to 5,000,000, giving me a timing system for 1/10th of a second. Each time the clock counter reaches 5,000,000, I store the count on the pulse counter and reset both counters in order to count pulses for the next 1/10sec. The weird thing happens when I want to include a hard reset. I want to be able to reset both counters manually if I need to. So I have the code:
module mokango_counter(hard_reset, pulse_in, count);
//define inputs and outputs
input hard_reset;
input pulse_in;
output count;
//define extra needed signals
wire max_reset;
wire timer_count;
wire pulse_count;
reg timer_reset;
reg save_data;
//Define reset conditions
//Do counting
counter time(.aclr(max_reset), .clock(CLOCK_50), .q(timer_count));
counter pulse(.aclr(max_reset), .clock(pulse_in), .q(pulse_count));
//check if we've reached our max time limit
always @(timer_count)
begin
if(timer_count==5000000) begin
timer_reset <= 1;
save_data <= 1;end
else begin
timer_reset <= 0;
save_data <= 0;
end
end
//Save counted data when necessary.
always @(save_data, pulse_count)
begin
if(save_data) count_out <= pulse_count;
end
//write output
assign count = count_out;
endmodule
I want the counters to reset on either me telling it to reset (hard_reset_ or 1/10sec has elapsed (timer_reset), which is what the red code line above should do, I think. But this isn't what it does do. Instead, it only updates counts when hard_reset is set to 1. If I set hard_reset to be controlled by a button on my DE2 board, it will only show me update counts (by linking the output count to the LED lights on the board) when I am holding down the button. So the system only updates when, as far as I can tell, max_reset is 1. I've tried to change the code by changing max_reset to a reg and putting it into an always statement that checks hard_reset and timer_reset via if statements and assigns max_reset a value directly, but that gives me the same behavior. The only time I can get the code to work correctly is if I drop the hard_reset condition from the red line and only have max_reset controlled by timer_reset, but of course then I lose the ability to reset on demand. What is my mistake and how might I fix it?
