Altera_ForumHonored Contributor13 years agoOR condition acts like an AND in Verilog? Short Version: I have an input to a module and a wire within the module. When either of these are TRUE, I want something to happen. However, only when the input is fixed TRUE and the wire flips t...Show More
Altera_ForumHonored Contributor13 years agoWhere are your reset conditions for timer_reset and data_save?
Recent DiscussionsIs Quartus Prime Pro 22.4 Compatible with Stratix 10 NX Series Device?Timing analysis - long combinational pathQuartusPro 25.3 Crashed after using the Signal Tap Logic AnalyzerDuplicate_hierarchy_depth / duplicate_registerAutomatically added negative node for TDS output doesn't work with Agilex 5
