10 years agoOptimal ALU
Dear all, I'm creating an ALU for a homemade NIOS II compatible processor with Quartus Prime, targeting the Cyclone V. I discovered that, depending on the operations ordering, the ALU has a differ...
10 years agoOk, but I fail to see how the exact encoding value for each operation matters, given the way FPGAs work.
Are you using a prioritized case statement to generate the logic, or is it a purely logical operation? Without seeing the code you write it is hard to make any substantial comment on the result you see. Examples (in verilog): reg [7:0] a; reg [7:0] b; reg [7:0] s; reg [1:0] f; // unordered: s = ({8{f==0}} & (a+b)) | ({8{f==1}} & (a-b)) | ({8{f==2}} & (a|b)) | ({8{f==3}} & (a&b)); case (f) 0: s = a+b; 1: s = a-b; 2: s = a|b; 3: s = a&b; endcase // prioritized/ordered: s = (f == 0) ? (a+b) : ((f == 1) ? (a-b) : (((f == 2) ? (a|b) : (a&b)))); if (f == 0) s = a+b; else if (f == 1) s = a-b; else if (f == 2 ) s = a|b; else s = a&b;
