HannesDE
2 years agoOpen QuestaSim from Quartus Simulation does not work on Linux
Hello, i currently have problems running Questa to simulate FPGA-Projects My Setup: -Fedora OS Version 38 -Quartus Prime Lite Edition Version 22.1 (Working) -Questa Intel Starter FPGA Edition 64...
HannesDE
2 years agoHi,
thanks for the reply.
The path is set in the options settings see the picture below.
When changing the path to something different i will receive a different error message which says questas could not be found. So i think quartus is finding questas but not the license file
This is the error message that is reffered to in the error maybe this helps
================The following additional information is provided to help identify the cause of error while running nativelink scripts================= Nativelink TCL script failed with errorCode: issued_nl_message Nativelink TCL script failed with errorInfo: Can't launch Questa Intel FPGA Simulation software -- make sure the software is properly installed and the environment variable LM_LICENSE_FILE or MGLS_LICENSE_FILE points to the correct license file. while executing "error "$emsg" "" "issued_nl_message"" invoked from within "if [ catch {exec $vsim_cmd -version} version_str] { set emsg "Can't launch $tool Simulation software -- make sure the software is properly installed..." (procedure "launch_sim" line 88) invoked from within "launch_sim launch_args_hash" ("eval" body line 1) invoked from within "eval launch_sim launch_args_hash" invoked from within "if [ info exists ::errorCode ] { set savedCode $::errorCode set savedInfo $::errorInfo error $result $..." invoked from within "if [catch {eval launch_sim launch_args_hash} result ] { set status 1 if [ info exists ::errorCode ] { set save..." (procedure "run_sim" line 74) invoked from within "run_sim run_sim_args_hash" invoked from within "if [ info exists ::errorCode ] { set savedCode $::errorCode set savedInfo $::errorInfo error "$result" $savedInfo ..." (procedure "run_eda_simulation_tool" line 334) invoked from within "run_eda_simulation_tool eda_opts_hash"
