ShubhamK
6 years agoNot able to program CPLD MAXV (5M1270Z) device : Error (209015)
We are trying to re flash the CPLD using USB Blaster with Quartus prime software it showed us the below error.
Error (209015): Can't configure device. Expected JTAG ID code 0x020A30DD for ...
YuanLi_S_Intel
6 years agoFirst of all, i would like to check. What are the programming file used for both JAM and USB Blaster method? Are they the same?
The reason is that, for JAM, you need different bitstream which is .jam file. For more information, you may refer to link below:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an586.pdf
- ShubhamK6 years ago
We use "POF" file to flash from USB blaster. The same POF file is converted into JBC file format. Then We are using this "JBC" file to flash from JAM STAPL Byte code player.
