VSavi3
2 years agoNot able to do fitting design with Quartus 22.1
I am able to fit the attached design with Version 22.1std.0 Build 915 10/25/2022 SC Standard Edition.
However, I can fit the design with ease in Version 19.1.0 Build 670 09/22/2019 SJ Standard Edition
Please suggest what changes required to in settings file.
Attached qsf file (extension changed to .txt to attach here) and report files both versions.
The error I got with Version 22.1std.0 Build 915 10/25/2022 SC Standard Edition is
"Error (170011): Design contains 249203 blocks of type combinational node. However, the device contains only 227120 blocks."
Please note, due to confidentiality, I can't make available the source codes for these builds.
Vikram
