Not able add signal tap in Quartus II 32-bit Version 13.0.1 Build 232 06/12/2013 SJ Web Edition
hi
I am getting Internal Error if try to probe the signal for a cyclone II device using Quartus II 32-bit Version 13.0.1 Build 232 06/12/2013 SJ Web Edition
Internal Error: Sub-system: AMERGE, File: /quartus/atm/amerge/amerge_merger_op.cpp, Line: 1101
database in unexpected state
Stack Trace:
0xf134: AMERGE_MERGER_OP::check_md5_for_one_partition + 0x1d4
0x17974: AMERGE_MERGER_OP::merge_partition_from_pdb_file + 0x7a4
0x18959: AMERGE_MERGER_OP::merge_partition + 0x6a9
0x18a9b: AMERGE_MERGER_OP::merge_non_empty_blackboxes + 0x10b
0x18d09: AMERGE_MERGER_OP::merge_all_partitions + 0x169
0x48d3: amerge_combine_netlist + 0x253
0x4ab1: _amerge_mini_merge + 0x11
0x15dcf: QSYN_FRAMEWORK::do_mini_merge + 0x2af
0x19947: QSYN_FRAMEWORK::write_qic_databases + 0x787
0x1f8e3: QSYN_FRAMEWORK::write_databases + 0xa3
0x1127e: qexe_get_tcl_sub_option + 0x1c4e
0x13ad6: qexe_process_cmdline_arguments + 0x526
0x13bd4: qexe_standard_main + 0x84
0x19dd6: qsyn_main + 0xa6
0x4e21: msg_main_thread + 0x11
0x1c98: _thr_final_wrapper + 0x8
0x5515: msg_thread_wrapper + 0x85
0x3921: mem_thread_wrapper + 0x31
0x60f1: msg_exe_main + 0x81
0x1ba1c: _main + 0x1c
0x24cd7: __ftol2 + 0x1e1
0x1fcc8: BaseThreadInitThunk + 0x18
0x67c5d: RtlGetAppContainerNamedObjectPath + 0x11d
0x67c2d: RtlGetAppContainerNamedObjectPath + 0xed
End-trace
- SyafieqS
IE mostly related to tool issue, do you mind to provide any the design to replicate and debug?
- SyafieqS
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to https://supporttickets.intel.com/, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 5/5 survey
