Hi thepancake,
thanks for helping me with this. The kit I have is the "dsp development kit, stratix ii edition (
http://www.altera.com/products/devkits/altera/kit-dsp-2s60.html)". I've tried the --pfl option without success and I could not find the --programmingmode option in the nios II flash programmer handbook.
The settings I have are:
sof2flash --input="/tmp/flash_programmer/sinusoid_dspbuilder/sinusoid.sof" --output="/tmp/flash_programmer/flash/sinusoid_cfi_flash.flash" --offset=0x0 --verbose --pfl
and
nios2-flash-programmer "/tmp/flash_programmer/flash/sinusoid_cfi_flash.flash" --base=0x1000000 --sidp=0x2021008 --id=0x449B04A1 --timestamp=1284050797 --device=1 --instance=0 '--cable=USB-Blaster [USB 5-1.2]' --erase-all --go --program --verbose
The "Nios II Flash Programmer" reports a successful flash but when I reboot the machine with the configuration switches set to "1110", It appears as if the board is trying to load the user design ("USER" and "FLASH_CEn" LEDs are on, "LOADING" flashing), fails and then falls back to the factory design ("FACTORY" and "FLASH_CEn" LEDs are on, "LOADING" flashing) which also fails to load ("FACTORY" and "ERROR" LEDs are on).
According to the kit handbook, the configuration controller is an Altera EPM7256 PLD and "the flash memory, Stratix II device, and configuration controller are connected so that data from the flash configures the Stratix II device in fast passive-parallel mode."
