15 years agoyes, you can program a system that does not include a Nios II into flash
with the Nios II Flash Programmer, you need to have the FPGA configured with design which includes a Nios II and a flash component in order to write out to the flash, but the configuration you write out to flash doesn't have to include a Nios II you could also take a look at the Parallel Flash Loader (PFL): http://www.altera.com/literature/ug/ug_pfl.pdf
