ManuDwivedi
2 years agoNo valid license for CoreDLA found
Hello, I have the Intel Premier Pro and building the bitstream for the example as per the instructions from Intel FPGA AI Suite for Arria10 SoC DevKit, section 3.3.2. Building the FPGA Bitstreams...
- 2 years ago
Hello! I was able to solve it myself, the issue was as simple as Quartus not being in $PATH. Which was given away because I wasn't able to invoke the quartus command and had to run it directly from ./opt/intel/intelFPGA_pro/quartus/bin/quartus.
export $PATH=$PATH:/opt/intel/intelFPGA_pro/quartus/bin/ does the trick.
AR_A_Intel
2 years agoWe are glad that you have found the solution for this issue and hope all is well. I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
