13 years ago
No paths found for timing analysis
When I compile the following code, the compilation proceeds successfully, but the classic timing analyser of quartus generates the warning "Warning: No paths found for timing analysis". The RTL viewer shows that the output is connected to the inputs accordingly to the expression in the process clause. Could somebody tell me what is wrong with timing analysis?
LIBRARY IEEE;
LIBRARY LPM;
USE IEEE.STD_LOGIC_1164.ALL;
USE LPM.LPM_COMPONENTS.ALL;
USE IEEE.NUMERIC_STD.ALL;
ENTITY Component_test_wo_library IS
GENERIC
mod_0_unsigned_width_n : NATURAL := 8;
mod_0_unsigned_width_d : NATURAL := 8;
mult_0_unsigned_width_a : NATURAL := 3;
mult_0_unsigned_width_b : NATURAL := 5;
add_0_unsigned_width : NATURAL := 8;
sub_0_unsigned_width : NATURAL := 5;
div_0_unsigned_width_n : NATURAL := 9;
div_0_unsigned_width_d : NATURAL := 5
PORT
--Input ports
Input1_I : IN STD_LOGIC_VECTOR(mult_0_unsigned_width_a-1 DOWNTO 0) := STD_LOGIC_VECTOR(TO_UNSIGNED(0,mult_0_unsigned_width_a));
Input2_I : IN STD_LOGIC_VECTOR(mult_0_unsigned_width_b-1 DOWNTO 0) := STD_LOGIC_VECTOR(TO_UNSIGNED(0,mult_0_unsigned_width_b));
Input3_I : IN STD_LOGIC_VECTOR(sub_0_unsigned_width-1 DOWNTO 0) := STD_LOGIC_VECTOR(TO_UNSIGNED(0,sub_0_unsigned_width));
Input4_I : IN STD_LOGIC_VECTOR(mod_0_unsigned_width_n-1 DOWNTO 0) := STD_LOGIC_VECTOR(TO_UNSIGNED(0,mod_0_unsigned_width_n));
Input5_I : IN STD_LOGIC_VECTOR(mod_0_unsigned_width_d-1 DOWNTO 0) := STD_LOGIC_VECTOR(TO_UNSIGNED(1,mod_0_unsigned_width_d));
Input6_I : IN STD_LOGIC_VECTOR(sub_0_unsigned_width-1 DOWNTO 0) := STD_LOGIC_VECTOR(TO_UNSIGNED(1,sub_0_unsigned_width));
--Output ports
Result_O : OUT STD_LOGIC_VECTOR(div_0_unsigned_width_n-1 DOWNTO 0) := STD_LOGIC_VECTOR(TO_UNSIGNED(0,div_0_unsigned_width_n))
END Component_test_wo_library ;
ARCHITECTURE a OF Component_test_wo_library IS
SIGNAL Read_Write : STD_LOGIC := '0';
BEGIN
Component_test_wo_library:
PROCESS (Input1_I,Input2_I,Input3_I,Input4_I,Input5_I,Input6_I,Read_Write) IS
BEGIN
Read:
IF (Read_Write = '0')
THEN
Read_Write <= '1';
END IF;
Result:
IF (Read_Write = '1')
THEN
Read_Write <= '0';
Result_O <= std_logic_vector( (("0" & unsigned(Input1_I) * unsigned(Input2_I)) + (unsigned(Input4_I) mod unsigned(Input5_I))) /
(unsigned(Input6_I) - unsigned(Input3_I)) );
END IF;
END PROCESS;
END a;
    I have conducted a few more experiments just to be sure that the problem is in the tool. Indeed, the tool calculates a worst-case tpd following some formula that takes tpd of every operation involved in calculations, e.g., tpd=(n-1)*(tpd,or+tpd,and) or the like.
    For instance, if I try the following code:
    PROCESS (Input_I,Read_Write) IS
    BEGIN
    Read:
    THEN
    Read_Write <= '1';
    END IF;
    Result:
    THEN
    Read_Write <= '0';
    Result1_O <= not Input_I;
    END IF;
    the tool cannot process it because there is no information about tpd of bitwise not operation in a process. Since the subtraction operation is performed as an addition of two's complement (a-b=a+not(b)), the tool cannot calculate tpd for this expression. Furthermore, it does not depend on a device family as I have tried different ones and have got the same result. However, the tool works fine for other operations logical, arithmetical etc.
    To check your assumptions about the cause of timing analysis failure, please compile the below modified code. You'll notice that timing analysis works as soon as the latch is controlled by a signal of known timing.
    LIBRARY IEEE;
    ENTITY no_timing IS
    PORT (
      Read_Write2 : STD_LOGIC;
      --Input ports
      Input_I : IN STD_LOGIC_VECTOR(7 DOWNTO 0);
      --Output ports
      Result_O : OUT STD_LOGIC_VECTOR(7 DOWNTO 0)
    END;
    ARCHITECTURE a OF no_timing IS
    BEGIN
        BEGIN
          IF (Read_Write = '0') THEN
            Read_Write <= '1';
          END IF;
          --IF (Read_Write = '1')
          IF (Read_Write2 = '1') THEN
            Read_Write <= '0';
            Result_O <= not Input_I;
          END IF;
      END PROCESS;
    END;
    --- Quote Start ---
    --- Quote End ---
    Yes, I agree with you and the example you have proposed works. Somehow, the tool can calculate timing for every operation but the "not" one unless the timing is controlled explicitly.
