13 years agoI have conducted a few more experiments just to be sure that the problem is in the tool. Indeed, the tool calculates a worst-case tpd following some formula that takes tpd of every operation involved in calculations, e.g., tpd=(n-1)*(tpd,or+tpd,and) or the like.
For instance, if I try the following code: PROCESS (Input_I,Read_Write) IS BEGIN Read: IF (Read_Write = '0') THEN Read_Write <= '1'; END IF; Result: IF (Read_Write = '1') THEN Read_Write <= '0'; Result1_O <= not Input_I; END IF; the tool cannot process it because there is no information about tpd of bitwise not operation in a process. Since the subtraction operation is performed as an addition of two's complement (a-b=a+not(b)), the tool cannot calculate tpd for this expression. Furthermore, it does not depend on a device family as I have tried different ones and have got the same result. However, the tool works fine for other operations logical, arithmetical etc.
