13 years agoTo check your assumptions about the cause of timing analysis failure, please compile the below modified code. You'll notice that timing analysis works as soon as the latch is controlled by a signal of known timing.
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.NUMERIC_STD.ALL;
ENTITY no_timing IS
PORT (
Read_Write2 : STD_LOGIC;
--Input ports
Input_I : IN STD_LOGIC_VECTOR(7 DOWNTO 0);
--Output ports
Result_O : OUT STD_LOGIC_VECTOR(7 DOWNTO 0)
END;
ARCHITECTURE a OF no_timing IS
SIGNAL Read_Write : STD_LOGIC := '0';
BEGIN
PROCESS (Input_I,Read_Write) IS
BEGIN
IF (Read_Write = '0') THEN
Read_Write <= '1';
END IF;
--IF (Read_Write = '1')
IF (Read_Write2 = '1') THEN
Read_Write <= '0';
Result_O <= not Input_I;
END IF;
END PROCESS;
END;
