12 years ago
No Output from my VHDL code !?
Hello all,
Being a newbie in VHDL, I am sure theres a stupid mistake somewhere. I just can not get my head around it.
There is no output . I am using activehdl as the compiling tool and it gives no error during compilation.
Can someone please help.
thanks alot
i wanna design an AOI_gate that the inputs are 2 std_logic_vectors.like this:
https://www.alteraforum.com/forum/attachment.php?attachmentid=6992
this is my code:
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.std_logic_arith.all;
use IEEE.std_logic_unsigned.all;
entity AOIGATE is
generic(N : natural:=4);
port(
    a,b : in std_logic_vector(N-1 downto 0);
    z : out std_logic );
end AOIGATE;
architecture structural of AOIGATE is
signal x : std_logic_vector(N-1 downto 0);
signal y : std_logic;
begin
    x  <= a and b;
    process(x)
    begin
        for i in 0 to N-1 loop
        y <= x(i) or y ;
        end loop;
        z <= not y;
    end process;
end structural;
when i write the code like this i have output:
begin
          x  <= a and b;
          z <= x(i)or y ;
          end loop;
end structural;
    Its probably because you forgot to put y in the sensitivity list. But why are you anding y with iteself?
    And the second bit of code is invalid because it is not inside a process.
    And you also need to learn the difference between signals and variables.
    Signals are only updated at the end of the process, so y will just take the value of (x(N-1) or y) because it wont be updated until the process suspends
