12 years ago
No messages in Modelsim [waveview & messageviewer]
I used to have messageindicators in the wave view of Modelsim. On my new computer they're gone. In my search for a solution I found that the messageviewer is empty. In my code i use multiple report statements like:
report "some text";
. I tried setting both msgmode and displaymsgmode to the value both, as was suggested on another forum. This did not help. Could you help me find the solution? I am totally out of ideas of how to solve this.
    I just tried this small example
    entity top is
    end;
    library IEEE;
        use IEEE.std_logic_1164.all;
    architecture arch of top is
    begin
      process
        begin
          wait for 1 ns;
          report "message 1";
          wait for 1 ns;
          report "message 2";
          wait for 1 ns;
          wait;
        end process;
    end;
    Using these commands
    vlib work
    vcom report.vhd
    vsim -i top -msgmode both -do "run -all"
    And it works for me.
    Can you try this and show us your script and transcript.
     //  Questa Sim#  //  Version 10.2a win32 Mar 15 2013#  //#  //  Copyright 1991-2013 Mentor Graphics Corporation#  //  All Rights Reserved.#  //#  //  THIS WORK CONTAINS TRADE SECRET AND PROPRIETARY INFORMATION#  //  WHICH IS THE PROPERTY OF MENTOR GRAPHICS CORPORATION OR ITS#  //  LICENSORS AND IS SUBJECT TO LICENSE TERMS.#  //#  vsim -do {run -all} -i -msgmode both top #  Loading std.standard#  Loading std.textio(body)#  Loading ieee.std_logic_1164(body)#  Loading work.top(arch)#1#  run -all #  ** Note: message 1#     Time: 1 ns  Iteration: 0  Instance: /top#  ** Note: message 2#     Time: 2 ns  Iteration: 0  Instance: /top
    Update: I have searched the great world wide web far and wide, but haven't found a solution, or a companion in misfortune. I'll keep searching and trying. But isn't there anyone who could point me in the right direction?
    yup, I do. I have them in a .do file after compilation of the files, and before the running of the simulation. I see the reports being "executed" as they appear in the transcript.
    Well, it has been a while, but I still have not found a solution. Is there someone with a creative idea that might work?
    Instead of using switches, try setting the variables in the modelsim.ini file
    done that, no changes. As said before, I do see them in my transcript, but not even a hint in the waveform or messageviewer. Also there are no filters on the messages.
    Are you talking about Tcl script output?
    I do recall having to use "echo" rather than "puts" in Modelsim Tcl scripts, otherwise the output goes to the originating console, rather than the vsim console.
    Perhaps you are seeing this too?
    Cheers,
    Dave
    puts and echo are no problem, what I mean is the following:
    in my testbench I have the following line
    report "clockgen: started loop" severity note;
    which show in the transcript as
    # ** Note: clockgen: started loop#     Time: 10 ns  Iteration: 0  Instance: /testbenchfile
    I want these to show up in my waveform, as they do on other computers I used. (Unfortunately I have no access to the modelsim settings anymore.)
    This works fine.
    result
    vlib work
    vcom C:/altera/13.0sp1/report.vhd
    #  Model Technology ModelSim ALTERA vcom 10.1d Compiler 2012.11 Nov  2 2012
    #  -- Loading package STANDARD
    #  -- Compiling entity top
    #  -- Loading package TEXTIO
    #  -- Loading package std_logic_1164
    #  -- Compiling architecture arch of top
    vsim -i top -msgmode both - -do "run -all"
    #  ** Error: (vish-3296) Unknown option '-'.
    #  Use the -help option for complete vsim usage.
    #  Error loading design
    #  run -all
    and I got the two messages in the message viewer.
    I will try to implement this in my project and see what that does.
    But that'll have to wait until tomorrow.
    Thanks for the help so far.
