MG850LM's avatar
MG850LM
1 year ago
Nios2 debug dosen't start
I can't start to debug nios2.
Loaded sof file is latest version.
LED light is flickering correspond to system clock on FPGA evaluation board.
Also generate BSP when modified cores in platform designer.
Debug configulation shows a message failed downloading elf file.
Could you tell me how to solve this problem.
kind regards
  • tehjingy_Altera's avatar
    tehjingy_Altera
    Hi
    Do you have any follow up question for this issue?
    Did you managed to try out the hello world?
    Jingyang, Teh
    tehjingy_Altera
    Hi
    Since there are no feedback for this case, I shall set this case to close pending. If you still need further assistance, you are welcome reopen this case within 20days or open a new case, someone will be right with you.
    If you happened to close this case you will receive a survey. If you think you would rank your support experience less than 4 out of 5, please allow me to correct it before closing or if the problem can’t be corrected, please let me know the cause so that I may improve your future service experience.
    Jingyang, Teh
