11 years agoNios2 Command Shell doesn't execute scripts
Hi
I'm using Altera Nios2 Command Shell [GCC4],Version 13.1 Build 162 on a Windows 7, 64 bit system. When I try to execute any command in the shell (e.g. elf2flash or sof2flash), the shell just seems to ignore it. There is no message like "unknown command" or similar, the shell just jumps to a new line and shows the prompt again. Several colleagues at work experience the same behavior even after a completely new installation of all the tools. What could be the problem? All other Altera tools work fine, I'm able to build my hardware and run Nios from Eclipse. Thanks!
