11 years agoHi Lukas
you could try to put this command in the shell script (nios2_command_shell.sh) which is called from Nios II Command Shell.bat in the nios2eds directory. The shell script has a section "Setup Nios2eds (GCC 4)". Try to put in here. Tell me if it works or not :) Jens
