TGao's avatar
TGao
5 years ago
NIOS II hint error,HEX file not correct
Dear Sir / Madam,
There're some errors when I create hex file using NIOS II .
"the steps : make targets--build--mem_init_generate"
Could you help to analysis the errors?
but it hints errors:
hex file not correct
right message: & right hex file
Ted.Gao
  • Hello Ted,
    There's a KDB with this issue solved, can you try these steps?
    Add your Hex file in the project directory (Should be visible in files window)
    1. Go to file ->Memory Files->Hex Decimal(Intel Format) File->select ->Ok
    2.A number of words and word size Tab will open ->Let it be default values don't change any values.
    3. New hex file will be opened in your
    4. go to tools->options->Memory Editor->Uncheck the option Read or write Hexadecimal Files (.hex) using byte addressing (Intel format)->Ok
    5. Open you hex file one after the other by double-clicking it (from project navigator->files)->hex file word size tab will be opened ->click ok
    6.Again go to tools->options->Memory Editor->check the option Read or write Hexadecimal Files (.hex) using byte addressing (Intel format)->Ok
    7. do the same for another hex file from step -3. Now generate the .pof file.
    Let me know if it works,
    Isaac.
    • TGao's avatar
      TGao
      HI Isaac, Solved Thanks! Ted.Gao
