YSuzu21
6 years agoNIOSデバッグについて
NIOS-Eclipse is used for debugging. The problem occurs when running The problem occurs when running Debug as → Nios II Hardware. When a CLK such as NIOS, JTAGUART, or PIO is directly input at 50MHz...
Isaac_V_Intel
Contributor
6 years agoHello Yasuyuki,
My first question for you is which version of NIOS are you using?
Regarding the ELF process failed, can you make sure that the NIOS debug reset output back to nios reset input QSYS?
See Figure 2 in the following link[1].
[1] https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_nios2_flash_programmer.pdf
- YSuzu216 years ago
Thank you for your reply.
