17 years ago
Newbie Question
Hi guys. I am new at VHDL and Quartus II software so this might be a really stupid or trivial question but I can't seem to figure out why the following code is giving a syntax error "near text "PROCESS": expecting 'if' (And several other 'expecting' something errors near words BEGIN, PROCESS etc.) Thanks in advance.
library ieee;
use ieee.STD_LOGIC_1164.ALL;
use ieee.STD_LOGIC_ARITH.ALL;
use ieee.STD_LOGIC_UNSIGNED.ALL;
entity test2 is
Port ( x1 : in STD_LOGIC;
x2 : in STD_LOGIC;
clock : in STD_LOGIC;
candy : out STD_LOGIC;
cent5_eject : out STD_LOGIC;
cent10_eject : out STD_LOGIC;
cent25_eject : out STD_LOGIC);
end test2;
architecture Behavioral of test2 is
VARIABLE temp_count, tot_count, out_check, double_o : INTEGER := 0;
SIGNAL double_out : STD_LOGIC := '0';
BEGIN
-- Output Logic process
output_logic : PROCESS (x1, x2, clock)
BEGIN
IF clock'event AND clock = '1' THEN
IF (x1 = '0' AND x2 = '1') THEN
temp_count := 5;
ELSE IF (x1 = '1' AND x2 = '0') THEN
temp_count := 10;
ELSE IF (x1 = '1' AND x2 = '1') THEN
temp_count := 15;
ELSE
temp_count := 0;
END IF;
END IF;
END PROCESS output_logic; -- The line with the error
-- CLOCK Configuration Process
clock_config : PROCESS (clock)
BEGIN
IF clock'EVENT AND clock = '1' AND double_out = '0' THEN
tot_count := tot_count + temp_count;
ELSE IF clock'EVENT AND clock = '1' AND double_out = '1' THEN -- Another Error here (Expecting a sequential statement or a "(")
CASE double_o IS
WHEN 10 =>
cent5_eject <= '0'; cent10_eject <= '1'; cent25_eject <= '0'; candy <= '0'; double_out <= '0'; double_o := 0;
WHEN 5 =>
cent5_eject <= '1'; cent10_eject <= '0'; cent25_eject <= '0'; candy <= '0'; double_out <= '0'; double_o := 0;
WHEN OTHERS =>
END CASE;
END IF;
END PROCESS clock_config;
outs_confirm : PROCESS (tot_count)
BEGIN
IF tot_count = 65 THEN
tot_count := 0;
cent5_eject <= '0'; cent10_eject <= '0'; cent25_eject <= '0'; candy <= '1';
ELSE IF tot_count > 65 THEN
out_check := tot_count - 65;
tot_count := 0;
IF out_check >= 25 THEN
cent5_eject <= '0'; cent10_eject <= '0'; cent25_eject <= '1'; candy <= '1';
ELSE IF out_check >= 10 THEN
CASE out_check IS
WHEN 10 =>
cent5_eject <= '0'; cent10_eject <= '1'; cent25_eject <= '0'; candy <= '1';
WHEN 15 =>
cent5_eject <= '1'; cent10_eject <= '1'; cent25_eject <= '0'; candy <= '1';
WHEN 20 =>
cent5_eject <= '0'; cent10_eject <= '1'; cent25_eject <= '0'; candy <= '1'; double_out <= '1'; double_o = 10;
END CASE;
ELSE IF out_check >= 5 THEN
cent5_eject <= '1'; cent10_eject <= '0'; cent25_eject <= '0'; candy <= '1';
END IF;
END IF;
END PROCESS outs_confirm;
END Behavioral;
1 Reply
    The compiler is complaining about missing end if statements. That's because the correct syntax is
    IF <cond1> THEN
      <block1>
    ELSIF <cond2> THEN
      <block2>
    ELSE
      <block3>
    END IF;
    Quartus has nice VHDL templates accessible in the editor, they can help you in case of VHDL syntax doubts.
