14 years ago
Newbie question about long control signal
hey, in my design i have a very long control signal, when i try complie the code i got error message like "Cannot split carry or cascade chain crossing xxx logic cells and starting on logic cell xxx into legal LABs." so i decide to break the singal manually to fit the maximum for a entire comlomn, and then connect them up.
the maximum length withour error is about 440 here, let's say i want the signal length to be 4000 and i want to break it into several 440 signal and connect them together(the next bit for the end of one column is the start one of the next comlumn), how should i write the code?
    library IEEE;
    use IEEE.STD_LOGIC_1164.ALL;
    USE IEEE.numeric_std.ALL;
    entity rc_adder is
    generic (
    vsize: integer := 440
    Port ( clk : in STD_LOGIC;
    a_in : in STD_LOGIC;
    b_in : in STD_LOGIC;
    r : out STD_LOGIC;
    load : in STD_LOGIC);
    end rc_adder;
    architecture Behavioral of rc_adder is
    signal a, b : STD_LOGIC_VECTOR(vsize-1 downto 0);
    signal rout : STD_LOGIC_VECTOR(vsize-1 downto 0);
    begin
    add : process
    begin
    wait until clk'event and clk = '1';
    if (load = '1') then
    a <= a(vsize-2 downto 0) & a_in;
    b <= b(vsize-2 downto 0) & b_in;
    rout <= rout(vsize-2 downto 0) & '0';
    r <= rout(vsize-1);
    else
    rout <= std_logic_vector(signed(a) + signed(b));
    end if;
    end process add;
    end Behavioral;
    --- Quote Start ---
    Show us what kind of code is producing that error..
    --- Quote End ---
    what i want to do here is add to very large number together, now i set generic to 440 which is ok, but i wish to have like 4000, so i think i need break the carry chain manually and connect it up, how to do that?
    I think you've come across a bug...
    Quartus should do it automatically for you. There's a synthesis setting for that and it's set to 70.
    A work arround is to use an LCELL primitive to break it, like this:
    library IEEE;
    entity rc_adder is
    generic (
    nblocks: integer := 40
    r : out STD_LOGIC;
    end rc_adder;
    component lcell
    port (
    a_in : in std_logic;
    a_out : out std_logic);
    end component;
    constant vsize : integer := nblocks * 32;
    signal sum : std_logic_vector(vsize - 1 downto 0);
    signal carry_a : std_logic_vector(nblocks downto 0);
    signal carry_b : std_logic_vector(nblocks downto 0);
    begin
    carry_b(0) <= '0';
    adders : for i in 1 to nblocks generate
    adder : entity work.adder_32
    port map(
    carry_in => carry_b(i-1),
    a => a(32*i-1 downto 32*(i-1)),
    b => b(32*i-1 downto 32*(i-1)),
    z => sum(32*i-1 downto 32*(i-1)),
    carry_out => carry_a(i)
    lc : lcell
    port map (
    a_in => carry_a(i),
    a_out => carry_b(i)
    end generate;
    add : process
    begin
    r <= rout(vsize-1);
    else
    rout <= sum;
    end if;
    end process add;
    end Behavioral;
    --- Quote Start ---
    library IEEE;
    entity rc_adder is
    generic (
    r : out STD_LOGIC;
    end rc_adder;
    component lcell
    port (
    end component;
    begin
    carry_b(0) <= '0';
    port map(
    &nbsp;);
    lc : lcell
    port map (
    a_in => carry_a(i),
    a_out => carry_b(i)
    &nbsp;);
    end generate;
    add : process
    begin
    r <= rout(vsize-1);
    else
    rout <= sum;
    end if;
    end process add;
    end Behavioral;
    --- Quote End ---
    thank you very much rbugalho! im quite new to vhdl and im not quite understand the part you write, can you please expain it a bit?
    I broke down the big adder into a series of 40 32 bit adders, creating a 1280 bit adder -- you need to write an "adder_32" module, which is a 32 bit adder with carry in and carry out.
    I pass the carry signal between two adders through an LCELL primitive to break the carry chain.
    I used a generate statement to generate the 40 adders and 40 LCELLs, instead of repeating the code 40 times.
