14 years ago --- Quote Start --- I think you've come across a bug... Quartus should do it automatically for you. There's a synthesis setting for that and it's set to 70. A work arround is to use an LCELL primitive to break it, like this: library IEEE; use IEEE.STD_LOGIC_1164.ALL; USE IEEE.numeric_std.ALL; entity rc_adder is generic ( nblocks: integer := 40 ); Port ( clk : in STD_LOGIC; a_in : in STD_LOGIC; b_in : in STD_LOGIC; r : out STD_LOGIC; load : in STD_LOGIC); end rc_adder; architecture Behavioral of rc_adder is component lcell port ( a_in : in std_logic; a_out : out std_logic); end component; constant vsize : integer := nblocks * 32; signal a, b : STD_LOGIC_VECTOR(vsize-1 downto 0); signal rout : STD_LOGIC_VECTOR(vsize-1 downto 0); signal sum : std_logic_vector(vsize - 1 downto 0); signal carry_a : std_logic_vector(nblocks downto 0); signal carry_b : std_logic_vector(nblocks downto 0); begin carry_b(0) <= '0'; adders : for i in 1 to nblocks generate adder : entity work.adder_32 port map( carry_in => carry_b(i-1), a => a(32*i-1 downto 32*(i-1)), b => b(32*i-1 downto 32*(i-1)), z => sum(32*i-1 downto 32*(i-1)), carry_out => carry_a(i) ); lc : lcell port map ( a_in => carry_a(i), a_out => carry_b(i) ); end generate; add : process begin wait until clk'event and clk = '1'; if (load = '1') then a <= a(vsize-2 downto 0) & a_in; b <= b(vsize-2 downto 0) & b_in; rout <= rout(vsize-2 downto 0) & '0'; r <= rout(vsize-1); else rout <= sum; end if; end process add; end Behavioral; --- Quote End --- thank you very much rbugalho! im quite new to vhdl and im not quite understand the part you write, can you please expain it a bit?
