New Quartus/Questa license Questa Issue
- Name: Leigh Pringle
- Email: [email protected]
- Company Name: Pringle Electronics Group
- Company Address: 16621 Madrone Ct. S., Pioneer, CA 95666
- NIC/Host ID: Primary:
000EC68F957E
Companion #1:
84A9386F026F
- License Type: (Node-locked or Floating) Node Locked
- If Floating, Number of Seats:
- License Purchased: Software for IPA Partner - Quartus Pro & standard, Questa, Intel FPGA AI Suite, NIOS-V, 1 Seat(s)
- The licensing person you contacted with previously: Daisuke Yoshida (ASAP program manager)
For your convenience, I have included last year's working license below: (note, the companion id is now primary and the new companion is different as I upgraded computers)
Intel Corporation Software and/or Intellectual Property License File
# Issued 13 June 2025
# Upgrade to these products will no longer be available after the Maintenance Expiration
# date unless licenses are renewed.
# Fixed Node License
# Primary Machine Name-080027cbc9ae
# Primary Machine ID-NIC ID 080027CBC9AE
# Companion ID-NIC ID 000EC68F957E
# Companion ID 2-N/A
# Product License Summary:
# 3 Questa*- FPGA Starter Edition (License: SW-QUESTA), 1 Seat(s)
# - Maintenance Expiration of 2026.06
# - License Expires 13-Jun-2026
# Software for IPA Partner - Quartus Pro & standard, Questa, Intel FPGA AI Suite, NIOS-V, 1 Seat(s)
# - Maintenance Expiration of 2025.09
# DSP Embedded FPGA IP Bundle - Partner including DSP Builder, 1 Seat(s)
# Questa*-Intel® FPGA Edition (License: SW-QUESTA-PLUS), 1 Seat(s)
# - Maintenance Expiration of 2024.08
# 32 Discontinued – Quartus® II Software (License: SW-QUARTUS-WE-FIX), 1 Seat(s)
# - Maintenance Expiration of 2022.12
# FEATURE START
# The following is a license file for the DSP Builder tool.
# Number of seat licenses is 1
# No license expiration date
FEATURE C4D5_512A alterad 2025.09 permanent uncounted 59C2BA2E72B0 \
VENDOR_STRING=7fkcz2dzAE7VAszbjLTzXH HOSTID="080027cbc9ae \
000ec68f957e" TS_OK SIGN="0069 BACA 50AD 1CDC CE35 B0BB 5E0A \
BA13 5B2A AD55 31B4 21FB D42A AAE4 CB4F 187A 72BD C6A2 7069 \
1A50 6801 1675 2062 D13B 13D5 2FD3 3A83 7853 C538 FE45"
# FEATURE END
# FEATURE START
FEATURE 6AF8_018B alterad 2025.09 permanent uncounted E2DE3AFA0F36 \
VENDOR_STRING=71kC3v5MjLCp4WFGu6RraL HOSTID="080027cbc9ae \
000ec68f957e" TS_OK SIGN="1B68 494D 629A 6CE8 1CCC 182F 98EF \
3634 0528 D874 9C12 1069 F4FE 1AB7 0FAE 009F B803 326E EBE0 \
E5A4 589C 250C B21F 691A 05FD 88FE FE14 9AD4 B1F3 3FAE"
FEATURE 6AF7_018B alterad 2025.09 permanent uncounted D71AE4C49491 \
VENDOR_STRING="iiiiiiiihdLkhIIIIIIIIUPDuiaaaaaaaa11X38DDDDDDDDpjz5cddddddddtmGzGJJJJJJJJbqIh0uuuuuuuugYYWiVVVVVVVVbp0FVHHHHHHHHBUEakffffffffD2FFRkkkkkkkkWL$84" \
HOSTID="080027cbc9ae 000ec68f957e" TS_OK SIGN="0F5A 5595 1521 \
26B8 5922 AC85 A305 5FFA 0628 1665 D2ED A54F DD75 BEA2 911A \
04E2 1EF8 3DB3 F0E2 7657 F34D 37FB 1BD1 B4AC 9CE0 07A2 1DE7 \
0A68 0DDD A39D"
# FEATURE END
# FEATURE START
# The following is a license file for the DSP and Embedded FPGA IP Bundle containing
# IP-CIC,IP-VITERBI/HS,IP-VITERBI/SS,IP-NIOS,IP-UART-16550,IP-RSCODECII,IP-TURBO,IP-RSCODEC-HS,IP-BCH,IP-LDPC,IP-TURBOV
PACKAGE ip_dspemb alterad COMPONENTS="6AF7_D036 6AF7_018C 6AF7_00FD \
6AF7_00BB 6AF7_00FE 6AF7_00A2 6AF7_00FC 6AF7_00E5 6AF7_00C2 \
6AF7_00FA 6AF7_013D 6AF7_010C 6AF7_0037 6AF7_0057 6AF7_0038 \
6AF7_0057 6AF7_0171" OPTIONS=SUITE SIGN="0782 1B6B E9DB D6CA \
CB8D 7F7F A676 3480 FF54 8045 1582 3F99 F761 032C 3295 1203 \
7C86 625D 7223 5096 3D34 838A 111C 406E 59EE 0946 3A2B E48F \
0EF5 0DBA"
FEATURE ip_dspemb alterad 2025.09 permanent uncounted C54A67FCCBC6 \
HOSTID="080027cbc9ae 000ec68f957e" TS_OK SIGN="06F1 6377 5213 \
3E2E A556 9E4B 8CC7 F0DA 135B D067 D9E2 5757 36D7 3E25 E440 \
14DB A6F8 A74D 91B0 492F 12E3 8A20 611C 40FD 07D9 FED6 8F9D \
81C9 E877 9090"
# FEATURE END
# FEATURE START
# The following is the license file for Nios® V/g General Purpose Processor Intel®
# FPGA IP
FEATURE 6AF8_018C alterad 2025.09 permanent uncounted 413E18149E7C \
VENDOR_STRING=abpO1kUDcsX9yZLB2S9DRO HOSTID="080027cbc9ae \
000ec68f957e" TS_OK SIGN="1104 3DB6 AF02 54EB 425A 0640 7B90 \
6037 F0A6 5A45 DF86 51D6 EF48 53BC 5F3A 1D21 03DD 2FCF A8B3 \
4A92 5469 82A6 EA93 1D8F 00FD 351D 99BF A607 CECF A62D"
FEATURE 6AF7_018C alterad 2025.09 permanent uncounted C301F38732AF \
HOSTID="080027cbc9ae 000ec68f957e" TS_OK SIGN="0EED 8C49 23DD \
94A2 A3FE 6F87 2D54 7C02 2050 CE2D 4F48 38D3 A150 F04B FE89 \
0618 B668 EE3F 7023 423E 3E60 2C4F 769E E9B2 34A1 3528 FB12 \
1B22 9DE9 0F4D"
# FEATURE END
# FEATURE START
# The following is a license file for Nios® V/m Microcontroller Intel® FPGA IP
FEATURE 6AF8_D036 alterad 2025.09 permanent uncounted 8FC83D6F65B3 \
VENDOR_STRING=2ljMZpIlaiIUTdWyXieG5l HOSTID="080027cbc9ae \
000ec68f957e" TS_OK SIGN="1930 FBC3 5EA2 498A F617 2713 838B \
0D33 F8E8 71BE 7F2E 0F37 AD77 7728 7166 0827 8E82 0383 10DC \
2A23 9338 A4A4 D6FE D012 AF51 B84A 0A68 8251 F17B 760A"
FEATURE 6AF7_D036 alterad 2025.09 permanent uncounted E40CABEA8B0C \
HOSTID="080027cbc9ae 000ec68f957e" TS_OK SIGN="1D71 9C11 5630 \
2372 E149 5D03 6E14 D101 3EB6 2D73 7C63 318F 0E10 3259 60AF \
0550 D256 DFAB 205F AE8F C425 3353 F789 002F 9252 943F 391D \
5518 E3E4 D875"
# FEATURE END
# FEATURE START
# This is license file for ModelSim Web Edition
# License Expires 13-Jun-2026
300 Your contract does not allow this feature.
# FEATURE END
# FEATURE START
# The following is a license file for the Intel Design Security feature for the Quartus
# II Software.
FEATURE quartus_nonvolatile_encryption alterad 2022.12 permanent \
uncounted 8CE61E791F45 HOSTID="080027cbc9ae 000ec68f957e" \
TS_OK SIGN="058E CC5A 37EF EA2F 2F5F 5383 4343 028C 66D4 0D36 \
82DE 206D D5DE 300B 01F7 04DE F191 88B7 36A9 DB26 2858 589C \
2697 B2BD A5B8 5CFA 2606 2BAD 8078 7905"
# FEATURE END
# FEATURE START
# The following is a license file for the Package part number for Quartus SE and Quartus
# PE
PACKAGE sw_pe alterad COMPONENTS="quartus_nonvolatile_encryption \
quartus_pro quartus" OPTIONS=SUITE SIGN="1255 1D06 FE67 D5A5 \
7DA0 B8D0 ED75 65F6 9D16 9CD7 3AAC 895F 04D5 954E 2147 1570 \
4E5B 2E36 13AB 8E7B 55C9 A3FC FCAB 6E9F 0BA0 59A5 CAFB 108D \
1CDE A6D3"
INCREMENT sw_pe alterad 2025.09 permanent uncounted 20800AF8885D \
HOSTID="080027cbc9ae 000ec68f957e" TS_OK SIGN="16E5 CA12 8051 \
232B 99C3 78AF C8DC 3573 81C2 5401 3E6A E244 0207 03DC 6FF5 \
02D0 4994 D481 FCF3 E4BF 3F0F 8A10 7EBB 2CFE 4A73 C7FB 8512 \
5F20 461D D55A"
# FEATURE END
# FEATURE START
# The following is a license file for the Quartus II Web Edition
FEATURE maxplus2 alterad 2022.12 permanent uncounted F1226A5EAD3B \
HOSTID="080027cbc9ae 000ec68f957e" SIGN="1840 A64A FE1E D55D \
C9EB 0972 6BC0 3E34 F609 6AB4 5360 0917 CE0F 7772 BC24 1707 \
97E6 6F7F 6ECC EADB 4D52 AE62 CDB6 700C A740 0CB2 64DF D011 \
E349 36A5"
FEATURE quartus_lite alterad 2022.12 permanent uncounted 8B01858D011B \
HOSTID="080027cbc9ae 000ec68f957e" TS_OK SIGN="05F5 D118 6661 \
61A4 DF7F 86A5 04F0 0158 E831 6D37 8452 47CD D7CA A6E1 7F46 \
0672 7605 0FB2 96B5 AC12 372D 746A 8116 E6E9 D87F 7A24 539F \
645A 11F4 8D3F"
# FEATURE END
# FEATURE START
# The following is a license file for the ModelSim
DAEMON mgcld path_to_mgcld
INCREMENT alteramtivsim mgcld 2025.06 13-jun-2026 uncounted \
1F8A2A9D2A0E4FC45014 VENDOR_STRING=6224EE40 HOSTID=080027cbc9ae \
ISSUER=Intel SN=298050154 SIGN2="1C24 3641 323F AAEB B48C 34B8 6BC6 \
8185 0583 BFFB 2D00 FF37 D06C 9F75 3998 0830 AAC2 B970 38F2 C1A4 FD2D \
E8CD 2FFF DBC2 C772 1848 DE49 AE7A 9870 7169"
# FEATURE END
# FEATURE START
# The following is the license file for Questa*-Intel FPGA Edition - Questa Plus
INCREMENT intelqsim mgcld 2026.06 13-jun-2026 uncounted \
0F3AFABD97CC884C1EDD VENDOR_STRING=158AFA9B HOSTID=080027cbc9ae \
ISSUER=Intel SN=198049210 SIGN2="0EFA DACE F3FF F735 C123 2039 A3CC \
0979 D6A0 76EA 0E16 72A4 B550 AECA CAE0 0EF2 0AA7 3B02 ACB0 EB7E DC25 \
6ED5 7C9E 7325 48A8 462F 7E8C C045 A726 9E82"
# FEATURE END
# FEATURE START
0F3AFABD97CB884C1DDD VENDOR_STRING=158AFA9B HOSTID=080027cbc9ae \
ISSUER=Intel SN=198049211 SIGN2="1237 9CF3 C8A3 92A1 F3ED 6D85 AD71 \
37EF 5207 BF93 3F3D 51BD 7C6B B442 0A29 198E 0C09 F2DB 6519 3BE6 3E0E \
3C46 3FF9 033C E333 4084 DF1E D725 A594 A585"
# FEATURE END
# FEATURE START
# This is license file for Questasim*-Intel FPGA Starter Edition
INCREMENT intelqsimstarter mgcld 2026.06 13-jun-2026 uncounted \
1FAA0A5D1CDFF80F07EE VENDOR_STRING=1D07A602 HOSTID=080027cbc9ae \
ISSUER=Intel SN=198049212 SIGN2="138F 7991 1304 2A1F B1DF 0BA3 3418 \
E8A7 364C 49DE 86AB 33D8 3C44 21E8 487A 1070 5FEB 0CE2 14A1 31E4 9565 \
12B2 524D 6950 DEFA A53F C86B A961 3A33 59C7"
# FEATURE END
# FEATURE START
1F9A0A5D1CDFF80F06EE VENDOR_STRING=1D07A602 HOSTID=080027cbc9ae \
ISSUER=Intel SN=198049213 SIGN2="0393 DB02 413C 6C42 863D EF2C A3DB \
2E46 7CFF 519E 3E6A FD79 EC7D C23E EB0E 1FD3 9B0C 2648 4851 CB21 145E \
C368 EA6C 79C3 DE27 C77B FF9E 3DA5 F32A 09CD"
# FEATURE END
# End of Intel Corporation Software and/or Intellectual Property License File. Issued 06/13/2025
Hi eeleigh
Thank you for the details.
In your post, you mentioned previously:
"Support said since I am non-commercial (ASAP partner), I have to post here."
and
"I used to be able to email the license people to fix errors promptly."
May I check whether the "Support" team and the "license people" you referred to are the same people, Daisuke Yoshida or are they different?
Thank you.
ZiYingE_Altera
