New Quartus/Questa license Questa Issue
Hi eeleigh,
Could you try using Questa®-Altera® FPGA Edition 2024.1? Since your license has a maintenance expiration of 2024.08, it will only support versions released before that date.
Please let us know if the error persists after trying version 2024.1.
ZiYingE_Altera
I already know 24.1 works, if you read my post, I suggest this is the issue. What I need is to be able to generate a correct license that supports the current version through my current license period, up to 2026.x. I used to be able to email the license people to fix errors promptly. This is likely going to turn my client away from using Altera.
- ZiYingE_Altera2 months ago
Contributor
Hi eeleigh,
To help us check this further, could you please provide the following information?
- Name:
- Email:
- Company Name:
- Company Address:
- NIC/Host ID:
- License Type: (Node-locked or Floating)
- If Floating, Number of Seats:
- License Purchased:
- The licensing person you contacted with previously:
You may send it to me via private message rather than posting it publicly on the forum.
Thank you.
ZiYingE_Altera
