OJin0
6 years agoNew Project: ElectricPiano_00_00, Request a review of what's wrong.
This is a new project to identify problems. (New project: ElectricPiano_00_00) Hello, Quarters Prime 19.1 behavior is strange. Attach the project folder. Request a review of what's wrong. conten...
SyafieqS
6 years agoHi Oksan,
What do you mean the Quartus behavior is strange? Can you elaborate it? Is it only for 19.1 or other version behave the same? Have you tried on other version?
OJin0
6 years agoHello,
In ElectricPiano_00_00, LPM_COUNTER has no problem at all. 50MHz input, 1/50 divided, 1MHz accurate output. OK.
However, there is a problem with the array of four synchronous counters (74160).
The output of the 4th counter does not output at the designed frequency.
There is an error in the simulation result, and there is also an error in the actual board output.
Below is my post on the forum.
- Below -
Right now I'm using version 19.1 only.
We found clues that differed between the function of the schematic and the simulation result.
As below.
Like Schematic, inst7 (TFF) should be triggered on X3 output to be normal.
However, in the currently simulated wave picture, inst7 (DFF) was triggered on X2.
In the PIN_F12 terminal of the board, 261Hz is output if it is normal as in the schematic, but the current 522Hz signal is actually doubled.
Why are they different from the schematic and simulation results?
I have attached the current project folder.
Thank you.
