OJin0
6 years agoNew Project: ElectricPiano_00_00, Request a review of what's wrong.
This is a new project to identify problems. (New project: ElectricPiano_00_00) Hello, Quarters Prime 19.1 behavior is strange. Attach the project folder. Request a review of what's wrong. conten...
SyafieqS
6 years agoHi Oksan,
What do you mean the Quartus behavior is strange? Can you elaborate it? Is it only for 19.1 or other version behave the same? Have you tried on other version?
OJin0
6 years agoHello,
Right now, I'm using version 19.1 only.
We found clues that differed between the function of the schematic and the simulation result.
As below.
Like Schematic, inst7 (DFF) is normal when triggered on X3 output.
However, in the currently simulated wave picture, inst7 (DFF) was triggered on X2.
In the PIN_F12 terminal of the board, 261Hz is output if it is normal as in the schematic, but the current 522Hz signal is actually doubled.
Why are they different from the schematic and simulation results?
I have attached the current project folder.
Thank you.
