Need to delete the 3 rehosts (wrongly generated)
- 4 months ago
I will send you the license file via private message.
Additionally, I recommend avoiding sharing personal information on the forum, as it is publicly visible. I have removed your personal details for now.
Richard Tan
Is this license file a purchased license or a no-cost license?
If this is a purchased license, contact the Altera Customer Service here:
https://licensing.altera.com/sslc/s/contact-customer-service
If this is a no-cost license, just simply generate another new no-cost license for the Questa Starter Edition.
Richard Tan
- ZWQ4 months ago
Thank you very much for your quick repsonse.
It's a no-cost license.
The current Computer is with the "Primary Computer ID" . And the license type is "Floated".
I would like to change the license type to "Fixed" with the same "Primary Computer ID". And I tried it on the window below, But when I clicked "Save", but it told this error:
Could you please help me with this ? Thank you very much!- RichardT_altera4 months ago
I will check with the internal team on this.
Do you have other NIC ID to generate the fixed license for now?
If not, I can generate one for you.
Richard Tan - RichardT_altera4 months ago
Unfortunately, we are unable to reset the rehost count for no‑cost licenses. The NIC ID is already associated with a floating license type and cannot be changed unless you have a purchased license.
As an alternative, you can:
• Use a different NIC ID for a fixed license while keeping the current NIC ID for the floating license, or
• Create a new SSLC account or ask a colleague to generate the license using the required NIC ID
Apologies for any inconvenience caused.
Richard Tan
