11 years ago
Need advice about coding style
Hello I'm Alex and I am novice for VHDL coding. if my english awful pls forgive me.
I trying to understand VHDL PROCESS statement. I try with 1bit full adder with carry save function in Quartus2 v15.
I write down code:
LIBRARY IEEE;
USE IEEE.std_logic_1164.ALL;
-- truth-table of full-adder
-- with three inputs: ci{carry_in}, a{first in} and b{second in}
-- and two ouputs: s{sum} and co{carry_out}
--  ci a  b | s  co
--   0 0  0 | 0  0
--   0 0  1 | 1  0
--   0 1  0 | 1  0
--   0 1  1 | 0  1
--   1 0  0 | 1  0
--   1 0  1 | 0  1
--   1 1  0 | 0  1
--   1 1  1 | 1  1
ENTITY full_add_1bit IS
PORT (
    ci : IN STD_LOGIC;
    a : IN  STD_LOGIC;
    b : IN  STD_LOGIC;
    s : OUT STD_LOGIC;
    co : OUT STD_LOGIC
END full_add_1bit;
ARCHITECTURE b OF full_add_1bit IS
BEGIN
    p0 : PROCESS(ci, a, b)
    VARIABLE
  aab,
  aob,
  axb,
  sxc : STD_LOGIC;
    BEGIN
  aab := a AND b;
  axb := a XOR b;
  sxc := axb XOR ci;
  s <= sxc;
  IF ci = '0' THEN
   co <= aab;
  ELSIF ci = '1' THEN
   aob := axb XOR aab; -- the same as (a OR b)
   co <= aob;
  END IF;
    END PROCESS p0;
END b;
but during compilation i recieves message
--- Quote Start ---
Warning (10631): VHDL Process Statement warning at full_add_1bit.vhd(30): inferring latch(es) for signal or variable "co", which holds its previous value in one or more paths through the process
--- Quote End ---
I follow the simple logic - let's compute new values then do all signal assignments and the question is
question1 : does pressure on variables so need?!
I rewrite architecture to new one, let's compiler do all work:
ARCHITECTURE b1 OF full_add_1bit IS
BEGIN
    VARIABLE
  result_i : INTEGER;
    VARIABLE
  result_v : STD_LOGIC_VECTOR (0 TO 1);
    BEGIN
  result_i := CONV_INTEGER(a)+CONV_INTEGER(b)+CONV_INTEGER(ci);
  result_v := CONV_STD_LOGIC_VECTOR (result_i, 2);
  co <= result_v(0);
  s <= result_v(1);
    END PROCESS p0;
END b1;
Finally i make schematic for this with 2mux1 blocks as for fun... in the attachments.
never use schematic for establishing any equation - you waste your time.
But result is the same with that scheme.
question 2: how to find the way to good coding style?
    yes - you get that because you didnt reset all output in the async reset branch.
    The prefered style for state machines now is a single clocked process. This avoids any latch creation and can be easier to track. The two process style is a throwback to very old synthesis engines that required separated logic and register processes. And so many textbooks taught this style. Now there is no restriction there is no need to separate logic and registers.
